BTW...Arrows and Knives penetrate BP vests...
Herewith is a beautiful recue Bow.  A friend sat it in a closet for years. te tip wasnbent over from sitting on the tip.  He gave it to me and I took it to an archery store.  The guy said it was useless as if you string it it woul break when pulled back.
I rigged up a frame to hold it and put tension  to twist it back in shape. It sat for a  couple years. The string on it I used to make sure the tips were in line .   Now it is back to its original shape.  I made  a new string for it and it draws fine.recurve.thumb.jpg.b2bf0c98564e6ad683c806e14728571a.jpg
I have a recurve bow with a fishing rig on it. Shot it one time, wasn’t paying attention and the string caught my middle finger. Snapped the first joint from my hand, had to have surgery and now have a permanent recurve in my finger.  Question was there a reason you strung the bow like you have it in the pic, instead of over the curves, just wondering. My grandson borrowed mine and haven’t seen it since.
The middle grandson borrowed my .308 and it’s not made it home yet. Will get it back, it’s a savage model 110, shoots great, killed a deer at 275 yards. they’ve all three picked out what weapons they want when I die. Makes it feel like they are rushing things.
The string across the bow i  used to  make sure the tips of the bow were in line with the middle of the bow as I applied clamps to bend the limbs back to normal.  Th is recurve rated at 50 lb.
I have a cheap 35 lb fiberglass that I have a fishing spool attached to. I have two  Compounds I use a trigger release. My bedroom is a duck managerie.  I was into painting decoys.
    • By noticon75
    • By realpilot
    • By OldATVowner
