(This Ad is from QUADCRAZY Classifeds, click "More" to find out how to contact the person who placed this ad.)
Brand New All Terrain Vehicles: ATV’s, side-by-sides, PWC’s, Boat's, and power equipment for salePOWER SPORTS DISTRIBUTION LIMITED is located in BALLYMENA, UK . Having over 7,000 square feet makes us the largest dealership in the UK combined with ...
More...
      QUADCRAZY NEEDS YOU!
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By davefrombc
      It would be  helpful at times to have a button  where we could cont the Admin. to  make some changes to  our posts.
    • By roggers
      Hi everyone,
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
