<embed src="http://www.metacafe.com/fplayer/482462/dangerous_dog.swf" width="400" height="345" wmode="transparent"  pluginspage="http://www.macromedia.com/go/getflashplayer" type="application/x-shockwave-flash"></embed><br/><font size="1">
			<a href="http://www.metacafe.com/watch/482462/dangerous_dog/">The Hole - video powered by Metacafe</a></font>
    • By DayBreakJim
      20230725_171507.mp4
    • By n4cer26
      I chased down the leak on my 97 Magnum 425. I have a nice leak coming from the water pump weep hole. I am being told the oil seal inside the pump needs to be replaced. Can anyone tell me what is involved in the repair. Can it be done without pulling the motor? Thank you!
      Sent from my SM-F926U using Tapatalk
    • By Phil
      I have a 2019 LTA-500 that needs a rebuild. The head assy and cover and cam is trashed. It seems like lack of oil feed to top end. Piston and cylinder is good. My main reason for posting is where is the cheapest place to buy parts?
      I'm in Australia but I have bought some parts before from Partzilla. I did find a reconditioned head assy on ebay from seller ATVcylinders, but still need a few things like cam oil pump, gaskets etc. I'm still looking for a workshop manual for this bike. Some photos of the damaged cam and head.
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By kingduskwolf
      I recently bought a 94 Yamaha kodiak 400 and I'm enjoying it, but something has got me curious there is a hole in the left front fender by the handlebars that isn't damage its clearly a factory made cut and when I google the same model it has that same spot but with a plastic covering over it. What exactly is this spot for?
