Oval shaped hole in front left fender of 1994 yamaha Kodiak 400?
Similar Topics
By mga
I just brought home a used 2005 Yamaha Big Bear 400 4x4. It needs front wheel bearings, and a new choke cable. I think i can handle those two items. However, when i went to look at it, it ran good, shifted good, brakes all workds great, but at home when i started it, it would idle nice, but when i gave it gas it seemed like it was flooding out and would die. If i just gave it a little throttle it built up RPMs but any more throttle it began dying out again.
any suggestions why it's doing that?
I'm looking for a service manual, but forum rules say i have to make 10 posts..lol
oops...i just realized i posted in the wrong section of the forum!!
By Myrtsbnye
Hello All,
I have a 1996 Arctic Cat Bearcat 454 and am in a bit of a quandry. I had a bunch of work done on it over the past couple years...new carb, rear brakes, rear axle and bearings. When the rear axle was replaced the shop noticed the left rear hub was stripped. Problem is, the part (1502-178) is no longer available. I've checked junkyards, ebay and other online parts sites across North America and nothing available. Hate to park the bike after all this work just because of a simple hub.
I have two questions...the front hub (part number 1502-177) how much different would it be from the rear hub? This part is readily available. Would the axles be different diameters?
If these are two different parts and we can't make them work, is it possible to take the existing stripped hub and just weld it to the axle? I know it may sound drastic but was wondering if it would not be too crazy?
Thanks for your time
By Matman
First time working with a Honda-Matic transmission. I didn't even know what I was getting into when I purchased this running beat up farm workhorse quad with black oil. I was thinking I could tear the cases apart and find the bad bearing, causing the random squealing noise when you put it into gear and give it gas. Upon opening the engine covers, I Learned about the Honda Matic automatic transmission and realized there's more than just an electronic shift motor going on in these quads. With my learning curve in major education mode, I'm now wondering two possible culprits to the squealing as I've torn the motor down and am staring at the Honda Matic transmission.
Two possible issues:
1. The bearing that is squealing is unfortunately inside the hondamatic unit hydraulic transmission which is apparently not serviceable? A new unit is $1,900 to replace it! Yikes!
2. The pull starter rope snapped and someone replaced with the wrong pull starter rope that eventually became severely worn out and the centrifugal lever/catch shows signs of wear from rubbing against the housing.
Thinking now the pull starter has nothing to do with a squealing that loud, so my attention is now on the Hondamatic unit,
Has anyone gotten inside their cases to inspect the Honda Matic transmission?
There's a only 1or 2 videos out there that are not helpful for tear down and inspection.
I understand it can't be rebuilt but wondering if anyone has looked deep enough into one to clean it out from running dirty oil? Possible identify bad parts.
I refuse to believe Honda is engineeering these as completely non-serviceable?
Thinking I will try to disassemble the Hondamatic unit m. Hopefully get into it and get all the dirty oil out and replace with fresh? Any special tools needed?
Any and all thoughts/experiences with Hondamatic units would be great conversation for me..
By Fish0rDie
Was told there was some good information on this forum, so I'm here engaging in some good ole conversation haha. Bought a buggy aka shitcart for 100 dollars. Thing was a woods toy for the past owner. Used and abused until she went boom and was left in a field to die. All things considered that may be an exageration, but the top end of the warrior 350 that was on board was absolutely mangled. Piston and head assembly were totaled. Have a new jug, piston, and head assembly, but struggling to get the crankcase back together without the transmission binding. Can share pics that are on my phone if anyone is interested in seeing this shitty story unfold.
By Hooks300Bayou
95 bayou 300 2wheel. This is my first four wheeler. The guy I bought it from showed me slight drip on his floor from a drain plug he recently retapped. I figured I could handle a small leak from a second hand machine. Well after a few times of riding it the bayou seems to be running low on oil. Now maybe this is normal operations as well so I refilled the oil. But the next day I notice my drip on the floor was slightly larger. I wanted to see this drain plug for myself so I took off the skid plate and found a pretty rough looking installed drain plug. It does have a small drop but also seemed to have an excessive gasket and maybe some grey looking “jb-weld” ish material around it. So that’s scary but I figure surely that’s not the only source since my floor spot Grew a bit. I went on to find recent moist around the head gasket for the top end. I’ve never seen it drip but it drips on the new starter the guy installed so it seems the head gasket leaks too. He did say he replaced that gasket when I inquired about the darken stains around that area of the motor. He said he replaced that gasket during. Ring replacement when the bayou was smoking. It no longer smokes by the way. So I continue on thinking well maybe I can do another top end gasket myself some day but still the oil on the floor suggests a more visible leak. I mean it’s not a lot but it grew as I mentioned. Then I find my what seems to be an awful thing. The pull cord and starter was replaced by the preavious owner and it appears there’s a busted area on the crankcase where the left side cover mounts to the L-case.I have not seen oil from there but that looks scary to me. Does this area hold oil? I wondered if it doenst maybe I’ll leave it be but if it does it’s probably the reason I lost some oil. I also found tonight oil on the rubber boot cover I think is for the drive shaft or something. Idk my first ride so I’m unsure of how to proceed. Especially with the case cracked like that. I don’t know how the engine works but if there is indeed oil there in the operation of things it seems like I must do a major engine over haul….. any insight would be so very helpful. I bought this for my daughter but I may have been bitten by going with such An older model.
Gallery Images
1By Guest,
7
8By onebad400ex,
3
5
4
9
8
3
1By LT250R,
4
2By LT250R,
3By SYKOLINCOLN,
0By Shortcut,
3
1
2
0
13By quadcrazy,
3By oxidized_black,
