96 kaw 400 4x4 bought a new starter for the atv and it just spins was told if the gears spin both ways a gear would have to be replaced in where the flywheel is need to know if this is true or false ?
    • By logray
      Hi all,
    • By HoldenBoy
      Hi all,
    • By crankin
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By shorty
      First ATV but owned 2 wheel versions all my (long) life. 1990 KLF300C for $500.. doesn't run yet but I'm an old automotive mechanic so not worried. Only a little concerned about the price of parts, certain this antique will need many
