    • By ScottV
      Hi all!
      Looking for some advice. I just bought a kawasaki mule fxr 1000. Super nice machine but as I said in the tag...total newbie. A buddy told me I need to be running tires low pressure out in the woods where I drive it. Is that so? He also said if I'm driving below a certain speed I should be in low gear range instead of 2 wheel high. Thoughts on that? Thanks everybody! I can't wait to dive into this site's content!
    • By Wicked
      View File 2015-2017 Polaris Ranger XP Crew 570 900 1000 service manual
      full service manual for 2015-2017 Polaris Ranger XP Crew 570 900 1000
      Submitter Wicked Submitted 08/12/2019 Category Polaris UTV
    • By Ilovemud57
      I just got a Ranger. What windshield do you prefer and why? Glass vs acrylic? Full vs partial? Flip out vs tilt? Best place to purchase?
    • By flyinbrian365
      View File 2018-19 Polaris Ranger 900-1000 XP Crew service manual
      2018-19 Polaris Ranger 900-1000 XP Crew service manual - Full service manual
      Submitter flyinbrian365 Submitted 09/19/2019 Category Polaris UTV
    • By Hagbard
      Looking for a DRIVE SPROCKET RETAINER PLATE for a 1987 LT230E (P/N 24751-35B01)? Good luck.
      Believe me I searched high and low, including contacting two OEM suppliers in Japan. No dice.
      Ran into this problem myself. The part is no longer available, unless you get SUPER lucky on eBay.
      My solution was to use the identical part from the newer ones, but you have to switch out the bearing and spacer bushing as well. Basically I took the retainer plate (46) and spacer bushing( 55) from a 160 motor I have for parts, and bought a new 6206 bearing which is the right size to match part (40) https://www.amazon.com/Bearing-30x62x16.../dp/B07XJ7H2VJ There's also a difference in thickness between the sprockets, so I added a couple 14ga. bushings as spacers
      So, referencing this parts diagram, you need to get everything from the bearing (40) on out. So, parts 40 (BEARING 09262-30084), 46 (RETAINER 24751-35B10), 47 (OIL SEAL 09283-38017), 48 (O RING 09280-70009), 54 (O RING 09280-21008), 55 (SPACER 27531-35B10), and 59 (PLATE, FRONT CHAIN GUIDE 27641-35B00).
      https://www.babbittsonline.com/.../50d08495f.../transmission
      If you need me to walk you through any of it I'd be happy to help.
