I remember my old bayou 250, It plowed snow, it hauled dirt, we even rode double on it. As long as you are not in it for racing it is a great quad. The lack of IRS in the back was the only reason we got rid of it.
    • By docdoug72
    • By heath
    • By Brian Emerson
      Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
      Thanks and regards,
      Brian
    • By Shadowace
      I have a 2016 artic cat 700 tbx seems like the power steering is not working what some obvious things that I can check.tks.in advance.
    • By mkibbe
      My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
