test drove the bayou 300
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By heath
i just bought a yamaha moto 4, i have sprayed 'start ya barstard' into the carb and on the spark plug and it doesnt even fire! although when i have the spark plug on the outside of the motor it shows spark, the engine also leaks oil from the starter,
By Brian Emerson
Hi Guys, this Quadmaster has an extremely loud bang after turning key off (from idle), scares the stock, dog and missus, any ideas on what to check.
Thanks and regards,
Brian
By Shadowace
I have a 2016 artic cat 700 tbx seems like the power steering is not working what some obvious things that I can check.tks.in advance.
By mkibbe
