Sounds like the carb air intake is clogged i would take the carb off clean it good soak everything with carb cleaner blow through all the passages and put it in ultrasonic cleaner for a while and see if that helps, also check the air intake hose to make sure its not clogged.
Could there be a blockage in the tubes before the air-filter box ? It sounds like the air box isn't getting enough air into it.
C.V.Carbs though can be very sensitive to the amount of vacuum of the intake/filter side of them. Not all C.V. carbs, but some cn be really sensitive. I'd check the airflow into the box first, then if it all looks like genuine system and clear, I'd try adjusting the slide needle as a first step. It's easiest.. Haha
A Constant Velocity (CV) carburetor works by using engine vacuum to control the opening of a throttle slide, which regulates the air-fuel mixture entering the engine. It has a diaphram attached to the slide instead of a cable.
    • By cfherrman
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
