By HoldenBoy
Hi all,
By Asand211
I've got a 1995 220 Bayou and the electric start does not work. When I got it the machine was pretty rough but I was told it ran less than a year ago. The key switch had been cut off and wires twisted after the key was lost. I bought a new ignition switch and repaired the wiring and it is working correctly. It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button. I verified there is no voltage going to the starter from the solenoid. The fuse in the solenoid is good. Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on. That doesn't make sense to me but I could be wrong. I would appreciate any help I can get. Thank you in advance.
By TravisCr
I bought this from a buddy to plow snow up in the North Eastern Washington- its been getting oil in the water and I've been changing the oil often and adding collant as necessary-
I've taken the stator cover off and I'm looking at the Oil Seal and water pump seal and they look good- Although I've ordered a factory oil Seal I'm looking at putting it in this afternoon-
I don't have the factory service manual- am I suppose to Add RTV to the Stator cover Gasket? I've seen some folks suggest grease other suggest RTV?
Any suggestions here- I'm trying to reassemble it tonight- I looked at downloading the manual but need to get up to 10 posts firsts it looks like-
I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but I got a good deal on the quad and a plow so I went for it
Its got a bit over 3K and runs pretty good- but I've had her tore apart for 3 weeks to figure out the oil in the coolant issue.
By quadcrazy
How to Choose the Right Cover
Conclusion
By Clydaho
Any other ideas?
Thanks for any help,
Clyde
