A Good Read For All
I found this and thought it would be of interest to some members ...
Don’t Let it Happen to You
A few short years ago the off-road world was enamored with 2-strokes thanks to their reputed simplicity and performance. Then, seemingly overnight, the four-stroke mill resurfaced and has since taken over nearly every aspect of the performance-quad segment. To many long-time 2-stoke devotees, the concept of valves, cam chains, and wide, flat pistons threw them for a loop.
There is no denying the reality that more moving parts equals higher rebuild costs, but there’s no reason to forget everything you’ve learned throughout the years in diagnosing a tired engine as a result. The following report is designed to shed some light on what to look for specifically if you’re uncertain whether or not it’s time for a four-stroke rebuild. Remember that it’ll save you money if you catch the problem before it actually fails.
A Game of Hours
If you just brought home your new ATV, take advantage of the fact that it’s yet unridden and pick up an hour meter. If that’s beyond your means, keep a log of time spent in the saddle. There’s no more an accurate means of determining when you’re due for a rebuild then by keeping track of the hours on the motor. Your ATV’s owner’s manual will provide intervals (usually on the conservative side) as to how often you should be freshening up the internals. Keep in mind that racing will speed up wear while gentle trail riding will extend service life.
Condition Induced Guilt
In keeping with the first entry, be honest with yourself (even if the hour meter says you’re still in the good zone). Have you been neglecting oil changes or racing with caked on mud? Have you flogged your quad in the sand/dust? Have you let air filter maintenance slide or ran the ATV without realizing it was low on coolant? These are all factors that can greatly accelerate time between rebuilds.
Lend Me Your Ear
Especially detectable at idle (beneath the rumble of the exhaust note); listen for clunking, thumping, or rattling sounds in the top-end. This is especially important if a sound you don’t remember hearing before suddenly pops up during a ride. Remember that not all four-stroke noises mean catastrophe: A loose flywheel or stretched cam chain are common culprits to the rattles. However, in either case, tightening down or replacing the worn bits can avert a full-on engine failure.
Compression Depression
Sorry to break it to you, but that old compression gauge that told you when the piston in your 2-smoke was due for a replacement doesn’t work on a modern four-stroke. This one has become a shop specialty, as most will have a leak-down tester capable of measuring static compression.
Read Your Oil
In the modern four-stroke, there are few indicators as valuable or as accurate as reading the lubrication-fluid that had just spent time circulating among the engine’s internals. If you’re suddenly spotting excessive debris in the bottom of the oil pan after a change it could very well indicate trouble. Also smell the oil being drained (even if it still looks fairly clean). If it smells burnt or like fried-clutch, it may be time to freshen things up.
Clearance Items
It turns out the manufacturers don’t provide the clearances of certain engine components just to be fancy. By checking these numbers, you can easily tell if things have worked themselves out of whack. Begin with valve lash and work your way into the internals with piston ring end gap, skirt clearance, and rod and valve guides.
Hard Starting
Four-stroke engines will often let you know something’s wrong a little bit before a full meltdown by refusing to fire up. If your quad suddenly seems harder to start or requires much more cranking than usual, take heed. Poor compression or improper valve clearance are often to blame.
The Rest of the Quad
If you’re still in the dark as to whether it’s time to consider a rebuild, take a look at the rest of your quad. Have you burned the knobs off the stock rear tires? Have you replaced the original brake pads yet? Is everything else in need of a refresher? A simple way to get a rough estimate as to how many hours are on the motor itself is to factor against the more-frequent maintenance performed.
No Smoking Zone
Yes it was perfectly natural to trail exhaust smoke in the 2-stroke days but if your four is puffing clouds, not a good sign! If your quad suddenly decides to take up the smoking habit, it’s possible the valves/ guide seals are starting to fail. Even more likely is that the piston rings have worn to the point where they no longer seal against the cylinder wall.
    • By drobbie98
      Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
      The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
      Thanks in advance.
    • By CJRenaJohnson
      Has anyone been here? I have been there a few times this year and I love it! It is quite muddy in parts of it, but there is something for EVERYONE there! They just hosted the season opener for Championship Mud Racing there and it was awesome! Its one of my favorite privately owned parks in this whole region!
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
      If you're an outdoor enthusiast looking for adventure and off-road fun, an all-terrain vehicle (ATV) is an excellent choice. ATVs have become increasingly popular over the years, offering power, versatility, and excitement for riders of all skill levels. As we dive into 2023, let's take a look at some of the best ATVs the market has to offer.
      1. Yamaha Grizzly 700
      The Yamaha Grizzly 700 is a top contender in the ATV world. Its powerful 686cc engine delivers excellent performance, whether you're traversing rugged terrains or towing heavy loads. With Yamaha's Ultramatic transmission, the Grizzly 700 offers smooth and seamless gear shifting, making it a joy to ride. Its advanced suspension system ensures superior handling and comfort, while features like electronic power steering and On-Command 4WD add to its versatility.
      2. Polaris Sportsman XP 1000
      The Polaris Sportsman XP 1000 is another top-rated ATV known for its power and performance. Equipped with a 952cc engine, it delivers impressive acceleration and speed, perfect for adrenaline junkies. Its high ground clearance and active descent control provide excellent off-road capabilities, while the electronic power steering ensures easy maneuverability. The Sportsman XP 1000 also offers ample storage space, making it a practical choice for longer adventures.
      3. Can-Am Outlander X mr 1000R
      The Can-Am Outlander X mr 1000R is designed for those who crave extreme off-roading experiences. With a 976cc engine and a specially designed mud-ready transmission, it's built to tackle the toughest terrains. The Outlander X mr 1000R features snorkel air intake and relocate differential breathers to provide exceptional water fording capabilities. Its aggressive mud tires and sturdy suspension ensure maximum traction and durability, making it an ideal choice for off-road enthusiasts.
      4. Honda FourTrax Rancher
      The Honda FourTrax Rancher is a reliable and versatile ATV suitable for a variety of outdoor activities. Powered by a 420cc engine, it offers smooth power delivery and excellent fuel efficiency. Its compact size and lightweight design make it maneuverable in tight trails, while the independent rear suspension provides a comfortable ride. The FourTrax Rancher also features Honda's Electric Shift Program, allowing you to effortlessly change gears with the push of a button.
      As you explore the market for your next ATV adventure, keep these top 2023 models in mind. Whether you prioritize power, versatility, or reliability, these ATVs offer exceptional performance and features to enhance your off-road experiences. Get ready to embrace the thrill of the outdoors and take on new adventures with one of these remarkable machines!
      Do you agree? Comment below
    • By cameronokeefe6
      I have owned my 84 Honda 200m for years now and I am wanting to see what i could do to upgrade horsepower , speed , performance , power etc and do it safely and not cause future harm to the engine.
      I was thinking on getting a 200x piston, will this work and give a good power increase ?  I have heard people have done this in the past and it works great. and i was also thinking on a 200x cam , will the 200x cam fit in this engine and make a difference also does it require the upgrading of any other parts and will i have to run 91 octane instead of 87 ? has anybody run this setup before and got good results ?
      I was also gonna go with a 200x carb but not sure if i have to buy an intake to hook it up or will it just bolt onto the 200m intake and fit fine ?
      If anyone has any suggestions and advice on what i could do it would be greatly appreciated ! thanks in advance.
