Hey Everyone,
Im new to the site. I just bought a very used 1999 Yamaha Bear Tracker that I new would need a little TLC. I just bought a new Air filter and changed the oil and differential fluid for it. As soon as I had it together it and put the air filter top on it would not start, as if its not getting air. I took off the lid and it started right up. After a few seconds it started spitting up fuel/foam into the air filter box. I took a video of it. Any thoughts would be helpful. Thanks!
[ame=http://www.youtube.com/watch?v=nVOCPnuRpsQ&feature=g-upl]1999 Yamaha Bear Tracker - YouTube[/ame]
i would probably first try cleaning the carb thoroughly, making sure the float needle is good. if not get a rebuild kit and replace everything from the kit. that is a ton of fuel coming back ... i would check all the fuel vent lines too. while you are at it, make sure the crankcase vent line is not plugged and check all venting lines, doesn't take too long to do or fix ...
i'm almost thinking it's a breather tube from the crankcase. i looked on my bikes but i dont have any connections of tubes except for the breather and to the carb. the filter looked like it was in place at the front, and with the amount of discharge coming out, it has to be alot of pressure, like the crankcase not breathing. but the vid is gone now. at first i thought it was oil/mixed/water. not sure mario
Thats what i was thinking. Im in no way familiar with that bike so thats why i was asking. Wonder if the head gasket or head is shot or cracked and pushing oil/water mix back into the airbox. Or maybe it was underwater and this is the crap coming out.
Im tapping out :-)
Sent from my SGH-T959V using Xparent Blue Tapatalk 2
Vent lines were pretty clean. I gave it a carb clean and oil change. Seemed to do the trick. I did notice that the previos owner put way to much oil in it. Also, there was some fuel in the oil. Not sure if that was the main problem. Any ideas why that would happen. I think the guy had this sitting for a long time. I hope thats the reason........Not sure though.
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Mister907
    • By jeffinotown
    • By crankin
