tracking down a short
I have a 98 suzuki quadrunner 250. i was jumping it off with my truck. the jumper cable hit the frame and i saw smoke from under the plastic, no more power, wont crank, i know i shorted something out and blew the 20 amp fuse. I have had the starter relay tested, it works. I took out the cdi it smells burnt, i have it hooked back up. The 20 amp fuse is not blowing now.
The funny thing is the green neutral light come on when the key is turned on but the run switch is off. when i slide the it to run the green light goes out. Any help would be great.
Could it be the cdi?
    • By Mhatayas
    • By Uglyside38
    • By Mhatayas
    • By hardcastle
    • By Louznmemind
      Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues...  It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
