got a 96 Big Bear Project Bike, the air filter doesnt fit tight with the box. Should there be a rubber gasket between the filter asembley and the intake?
Would this gasket come with a new filter, can I just buy this gasket. searched all over but cant find that part or a diagram showing it. Have the owners manuel and service manual but neither show it.
    • By joshualutz
    • By USRaider
      Hello all!
    • By marlon smith
    • By kevinohio
    • By tin
