I have a 2003 yamaha big bear 400 4x4. it was working no problem and now the starter is staying engauged with the switch on or off Ive checked all the fuses and wire and everything looks ok took the wire off the starter and tapped on it also still engauged dont no what else to check or do any help would be alsome Thanks.
The starter motor is staying powered? That would be the starter relay sticking. If the starter is being driven by the engine while its running than the one way bearing on the flywheel has failed.
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Atomusthenes
    • By RadRob
    • By Tim Keiper
