Have you tried the light after you start the quad with the pull rope. My daughters light will not light up unless it's running. Their should be a starter relay also if it goes bad it will effect the current to the starter. Like Ox said look at the fuses it's quick & a cheap fix finding a bad wire will be harder. You could puul the starter and use a battery charger to see if it is turning when you supply power to it. It's just safer and easier with it out of the quad.
Edited by hangingon
The light does not come on when it is started, the weird thing is at first I could just turn the handle a little bit and the elec start would work but now even tugging on the wires doesn't work and my 4 wheel drive is not engaging, ill check the fuses for but think I have a short, any certain location for the fuses
Thanks guys a found a broken wire from my start switch to the lights and connections that is after I took everything off, oh well needed to grease and tighten chain anyway
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
