By Memphis
Regards
By Gwbarm
I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
By Atomusthenes
By neilroy87
