    • By Shorty51
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By DexKing
      When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
    • By TravisCr
      I bought this from a buddy to plow snow up in the North Eastern Washington- its been getting oil in the water and I've been changing the oil often and adding collant as necessary-
      I've taken the stator cover off and I'm looking at the Oil Seal and water pump seal and they look good- Although I've ordered a factory oil Seal I'm looking at putting it in this afternoon-
      I don't have the factory service manual- am I suppose to Add RTV to the Stator cover Gasket? I've seen some folks suggest grease other suggest RTV?
      Any suggestions here- I'm trying to reassemble it tonight- I looked at downloading the manual but need to get up to 10 posts firsts it looks like-
      I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but  I got a good deal on the quad and a plow so I went for it
      Its got a bit over 3K and runs pretty good- but I've had her tore apart for 3 weeks to figure out the oil in the coolant issue.
