Similar Tagged Content
By Aj Hurtibise
I have a 2000 Honda trx90 I got from a buddy for free he said it needed a carb so I put his old carb back on it to try to get something out of it and it does not have any Spark. I already replaced the ignition coil I don't know much about four wheelers but I am a technician so I do know my way around a motor any electrical help would be wonderful or specs I don't have the best digital multimeter either.
By Wiktorix Gameplays
Can I use an old snowblower engine in my 90cc quad? The old one blew up.
Thanks for the help.
By Ajmboy
View File 2003 Scrambler 50 Predator 90 Scrambler 90 Sportsman 90 Service manual
2003 Scrambler 50, Predator 90, Scrambler 90, Sportsman 90
SERVICE MANUAL
Submitter Ajmboy Submitted 05/28/2017 Category Polaris ATV
Similar Topics
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By Ajmboy
With this cold snap, I noticed yesterday that the battery on my grizzly was a little weak. even clicked a few times before I got it to start. I'm thinking of picking up a batter tender/ trickle charger so was wondering what people use to keep their ATV battery charged up. I was looking at these on amazon. They both have good reviews.
or this one
Kind of like this one because if the accessory plug
By VikingTrad3r
picked up my third timberwolf 250 for my daughters. these are great light weight little quads.
have a strange one for you. the quad will NOT start in neutral. it will start in first.
if i lift up on the gear selector just enough to hear the little click (its not loud, sounds like a contact clicking, perhaps the neutral safety switch?) the light will go out, but it won't yet be in first either. that is how i have shown my daughter to start it and she can.
id like to carry out whatever repair is needed. i have the pdf of the shop manual but it doesn't really have a flow through diagram.
any help appreciated! thank you.
i need to add something. it feels like i can switch into another gear BELOW neutral.
so if i switch to neutral, i can keep pushing the gear selector, and it has another click below the neutral. the light stays on, and when i pull up into first it kind of feels like it has two positions it moves through to arrive at first.
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
