Similar Topics
By Randel1
I'm having a problem getting a CDI unit that works. The parts list calls for a 4XE-85540-00-00 CDI unit. The one currently on the ATV works but there seems to be a problem with the spark advance curve. It will idle fine an rev. to about 1.5K then starts bogging down sputtering, popping and basically running poorly. If you can get it above 2200 RPM it runs better. I have ordered and returned about 5 replacement modules that will not work at all. The unit currently on the bike has no part numbers or identification other than a Mitisibuchi logo. I am wondering if anyone else has experienced similar problems with replacement CDI's and if so what is the fix? So far I have not found a replacement CDI that will supply an pulse to the Ignition coil.
By ATVNetwork
news A powerful trail machine ready to tackle the hardest adventures.
Polaris unveiled the 2021 Sportsman 850 Trail Edition ATV with factory-equipped enhancements to tackle the roughest terrain. View the full article
By Budman
After purchasing a lightly used 2018 570SP (300 miles on it) I noticed that the display was flashing on and off. I remember reading awhile back that this was a common problem on the 18 model. I can't remember what the fix is. It also turns over slow even though the battery is charged. Anybody know what the fix is on this issue?
Budman
By ezduzit
New to me xpress i believe shuts down when put into reverse, but if i hold the override button it will remain running.
This is not normal operation based on my scramblers i've owned before. She also grinds when i attempt to select high gear and wont engage. lastly she runs great in low gear . I dont know how to fix this or where to begin my troubleshooting. 1994 polaris 300 2x4 thanks in advance for any suggestions/solutions
By technofarmer
Hey there, i have recently put a new drive belt on my 11 Polaris Sportsman 500 H.O. It has 44 miles since putting the new belt on and should be nearly broken in as i hear it takes 50 miles to do so? Anyhow it has had a little trouble with slipping since i put the new one on a few months ago. Now whenver i go down a hill the belt seems to be getting caught in one clutch if not both and then it has to run a high rpm just to go a low speed. Today it did that again going down hill, i stopped, put it in neutral and when going back up the hill i had to turn it off, put it in neutral, let it roll back down the hill a little, then restart it, low range and it was slipping but thankfully i was able to make it up the hill.
So what might the problem be? Is this a need for another new belt? New clutches and belt? Or just get something else? BTW the brand new belt i put on it, is a factory one, an exact replacement for the original.
