I have this NO NAME 90cc atv. Guessing that because of the 87ccm stamped on the jug. Any way I have spark,fuel getting through carb and into the cylinder. Valves are at .003. Double checked those. The remote control "board" is crap all corroded. It will 1 in ever 100 times think of starting, normally if I have left it alone. won't start on ether either. There is not a single ID marker on this thing. It does have the typical Honda knock off engine. I have the Honda Manual for that, but am out of ideas!!!!!!! the only other thing is there are 3 wires where a rear brake light used to be? or a kill sw. with key on 1 is hot the other 2 ???
