Having issues with the 4X4. It is locked in and will not come out . The 4x4 and the differential are not engaged with the buttons but they are engaged . I have dried out everything and unplugged as well. I cant remember which lights come on when the key is off and even out. :aargh:
    • By HoldenBoy
      Hi all,
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By Adamb2025
