I purchased the seals for water pump.finally got old one out and noticed shaft bearing are pretty loose.i see the clip on outer side of case against outer bearing.shaft will move towards inside a little ways then stops.how does shaft and bearings an oil seal come out. I cant find much help in manual
1994 bayou 400 4x4
KLF 400B
  • 5 years later...
find a website that sells parts online like a dealership they will have detailed parts diagrams that should give you a good break  down of how it goes to gether
    • By LCP92
    • By Olchap
      Hi, I am new to  this forum and I am happy to be here.  I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is.  I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing.  I checked up near the radiator and found nothing.  Where else should I look?  See image below.
    • By Matdum
      Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
      thanks a lot !
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
