By joezee13
By middlebrookgt
By Atomusthenes
By DexKing
When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
