2012 Ski-Doo SUMMIT X 800R 163 ( Milwaukee)
By OldATVowner
By quadcrazy
QUADCRAZY NEEDS YOU!
By hengstserepair
Nuetral: Runs as expected
Lorne
By sandman001
This 2006 ArticCat dvx400 didn't have a reverse cable. I got one and am wondering how it routes? If someone has a dvx400, could post a pic of there reverse cable routing, it would be greatly appreciated. Thanks
By Rockbottom
any ideas how to correct
thanks ahead
