Recently purchaced a 2005 king quad 700.. I bought it in pieces from a buddy that needed cash. I had rode this before he tore it apart so i know everything was good. It needed a new cylinder ad piston which came with it. I have got it all back together and it would only run if you held the throttle open a little bit. I thought timing so i checked it again, took apart and timed over but still nothing.. Finally i turned the throttle position sensor and it starts and idles but still don't seem just right. Still timing? anyone know how to properly adjust tps? any thoughts? thanks
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By kevinohio
      My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
    • By Martin82
      Hello to all,
      Im looking for a main wire harness for Polaris sawtooth 200,
      Thanks for info
    • By BillR94
    • By middlebrookgt
