when i changed mine, there were two wires (a red and a white) that went to a connection plug, i had to use a nail to dislodge the wires in the one half of the connector and put the red wire where the white was and white wire where the red one was. it was an aftermarket stator ...
Ok I finally got some time to get back to the problem at hand. I switched the wires to see if that was the problem but no. But like I said before after I replaced it, it did run for about 20 mins then shut off and now will not restart. I need some big time help here please.
    • By cfherrman
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
