Do you guys have any idea what is this bolt under the duck tape (in red circle)? There is some bolt which can be adjusted. I have opened clutch mount and this one seems to go inside the gearbox
Green arrow is clutch adjustment but what is thisone on the top?
Kuvauppi
Edited by andeanis
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By quadnut20
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
    • By Mudseeker149
      Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
