Hi everyone. My apologies if I'm posting in the wrong area. However my son and I are working on another project. We have a Baja 50 ATV. The problem we're having is that it will crank but doesn't start. Below is everything we've done so far.
1) Drained old Fuel-Filled with fresh fuel.
2) Drained Old oil-Filled with fresh oil.
3) Replaced CDI & Rectifier Regulator
4) Replaced Ignition-because it did not have keys for it
5) Checked Spark plug for Spark
6) Checked to make sure the fuel line wasn't blocked.
7) Checked Fuel Filter-Good
8) Checked battery - All connections were tight
9) Checked Solenoid
0) Checked the emergency tethered kill switch, however we're not exactly sure about this because it doesn't push in or pull out, just spins.
Could anyway shed some advice on what we're missing or forgetting. I'd very much appreciated.
    • By realpilot
    • By OldATVowner
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By Rockbottom
      What should i test next?
      thanks ahead
