1994 Suzuki ltf250 - Cranks Up~Then Quits
BURNETT73
I just bought a quadrunner yesterday for a project and it has been sitting for a while we put some gas it in and it trying to crank up but once it would it wouldn't stay running the gas was on we are thinking it's to do with the gas peacock or the carb. Any ideas or suggestions on how to fix it?
i would take the petcock off first, or even the hose leading to the carb and make sure it flows. i would check your voltage regulator with an ohm meter and make sure you are getting steady current. last i would take the carb off and clean it thoroughly, the wire twist ties you get for garbage bags, strip them to the metal and run them through everything and use lots of carb cleaner, make sure the needle and seat are good, needle should have a nice point to it. make sure the float level is at the right height too.
Edited by oxidized_black
    • By Starsat
      The choke lever doesn't stay in position on my 2001 Yamaha Kodiak.  The model is YFM 400.  I have to hold the lever to the choke position manually for some reason.  Any Ideas as to why?
    • By goodkid_6
      I have a 1989 quadrunner LT160. I am looking to replace the plastics. I can't find them for the 89 specifically but I do see plastics for a 91 - 01. Is there a difference in the 89 to the 91 - 01 plastics? From the photos, they appear to be the same with the exception of the holes for the front and rear racks.
      Please help clarify if you can. Thanks!
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By Uglyside38
    • By Frank Angerano
  • Similar Tagged Forum Content
