No one has any weird habits? One of mine is I have to put a book or something in front of the time on the digital cable box before I go to sleep. If I wake up in the middle of the night I will just lay there and watch the time and wont be able to go back to sleep. :twitsy:
    • By ruslan1o1
      Hey everyone looking for a suggestion of where i can start looking. But first I'd like to explain what happened. Took the bike this morning got it started in 6 degrees celsius in 6-7 kicks? No choke. Drove 6km and when shifted to next gear bike decided to just shut off, stopped checked everything out seemed good, started first kick and on i went, drove maybe another 2km bike did same thing but this time it took me 10-15 kicks to get it started, on the third time after a kilometer decided not to start at all. Kicked it like a 450 a couple hundred times, nothing. So far checked gas is good, bypassed fuel filter and on/off valve to eliminate that problem, hot wired the kill switch in case something got corroded there. Nothing. Any suggestions would be welcomed. (Heard valve adjustment are a must do?)
    • By skittle021
      Photos:
    • By skittle021
      So I've got a Hisun 550 (clone of a Yamaha Rhino 660) that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
      Photos:
    • By Dgafchikk
      Whats the difference in the red honda atc engine and the black honda atc engine?
    • By garysaul
      Rear brake pedals very soft,I think all of a sudden as the kids have been riding this one.
      Changed pads-calipers in great shape
      Bled brakes--no change--apparently need new master cylinder?
      Never had any type of vehicle where the master cylinder actually failed
      Partzilla-$144---amazon $25 --has anyone used a chinese one
