Went to neal motorsports in long prairie minnesota and they had one 2012 brand new for $4,000. Too good of a deal to pass on. They are making room for the 2014 so they all had great deals but it was the last 2012 they had. They had a 2013 700I LE for $6,450 I almost pulled the trigger on but figured I'd start with the 450I since it's my first atv.
Warn plow and winch kit $579 with shipping and probably 3 hours for an install. So far she runs like a top and I have a year to ad on the 4 year extended warranty for $580. The way she runs I might just keep my money. I haven't topped her off yet but I can get up to 35 without even trying. Easy steering feels much better than my parents foreman which after a drive I can feel it in my shoulders. I really can't wait to get the plow in to see how she pushes snow and in a few months I can see how she handles in the mud!!
    • By WeeBee
    • By HighPlainsIT
      My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
    • By 97kingquad
    • By Ant-Knee
      I recently picked up a '97 Prairie 400 4x4 that didn't run. I didn't get much information from the previous owner except that it was running a couple of weeks ago, then started losing power. After that, it just wouldn't do anything... no crank, no start. The electric start didn't do anything and the pull start seemed locked up. When I got it, it had no fluids whatsoever—no oil, no coolant, nothing. I figured the engine was seized. I took the pull start recoil off and tried turning it with a wrench but it didn't move. I took out the spark plug and put some lubricant in the spark plug hole. After a while, I was able to get it moving and it turns now but isn't super easy to turn. I put oil and coolant hoping it would fire up but still nothing. I took out the starter and tested it and it worked perfectly. I tested the starter solenoid and it clicked so I assumed it is working. The battery is good and holding a charge. I also put in a new spark plug as the old one was somewhat corroded but didn't look that bad. After I tested the starter, I put it back in and ran some power directly to the starter. It started cranking the first time I gave it power but didn't do anything after that one time.
      Any ideas of what I should do next would be greatly appreciated. Always wanted a quad so I really want to make this work but not sure if it is do=able.
    • By Kansasprairie400
      Was riding my prairie 400 the other day started to miss out and then just died no spark I pulled the seat off. The battery was swelled up. I replaced the battery would not start no spark pull the control unit and there was a round quarter inch hole broken out of the Gel coating on the back. I figured it was an internal issue and ordered a new module still no spark, replace spark plugs and coil still no spark. I’ve checked all the wiring and cannot find any issues. I am not that tech savvy and really need some help. Anyone have any ideas? thank you.
