Working on friend's Honda Rincon. His front tire doesn't hold air well. I'm going to fill to max bead seat pressure, but i'm wondering about these bolts on the rim. Are these two piece wheels? Can I retorque the bolts?
i have the same rims on my grizzly, they are decorative only, just plastic heads about 1/4" depth ...
ITP SS 108s i think the rims are ...
i had a problem with one of mine too, i ended up getting "slime" and running it around both beads ...
it worked ...
BTW, whats this slime you speak of?
No joy, gooed the Slime around and under where the wheel rim meets the tire. Bubbles up in 8-10 places. These are old wheels off an 86 quad runner. Polishing a turd. A guy on craiglist is selling a set for $50USD. Think I`ll go that route.
    • By TomJulio
    • By gordonmacritchie
      all fuses are fine
    • By toe420
    • By TomJulio
