I'm new to the sit. I already need help I bought a 2000 big bear 400 would crank and run fine then after riding for a while it would cut off or either I cut it off and would not start back up after sitting for a while it would crank back up. Any help??
after it sits, you say it starts and runs?
i would try a new coil ... you might want to cut back the wire to the plug cap first, give that a try with some fresh un-corroded wire ... normally, a coil with work fine being cold until it over heats itself, then it will stop the spark until it cools off ...
    • By realpilot
    • By OldATVowner
    • By quadnut20
    • By cruteg8
