I'm new to the sit. I already need help I bought a 2000 big bear 400 would crank and run fine then after riding for a while it would cut off or either I cut it off and would not start back up after sitting for a while it would crank back up. Any help??
after it sits, you say it starts and runs?
i would try a new coil ... you might want to cut back the wire to the plug cap first, give that a try with some fresh un-corroded wire ... normally, a coil with work fine being cold until it over heats itself, then it will stop the spark until it cools off ...
    • By quadnut20
    • By Mister907
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
