92 timberwolf valves stuck
By semicolon
By N00bie
By skittle021
Photos:
By Lukequinn
I have a Yamaha beartracker 250 that I can’t seem to get running right
i am after replacing the spark plug, carburettor, and the carb boot to the engine when she starts she revs up like mad even when the mixture screw on the carb is fully in when running she pops and stalls and won’t rev up
has anybody have any idea what could be wrong with it thanks
By skittle021
So I've got a Hisun 550 (clone of a Yamaha Rhino 660) that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
Photos:
