K&N filters are good. If you havent done it in a while, overhaul the carb and adjust the valves.
I would stop with the above because you can only get so much out of a 250. There should be jet kits you can get for the carb. There are performance mufflers available but they are expensive and probably not worth putting on your model.
    • By TravisCr
    • By p5200
      I'm wanting to try and get the machine on blocks. I just want to verify my AWD is working. How do most of you go about doing this. I want to be safe since it will be in gear with hopefully, all wheels spinning. Thanks! 🙂
    • By p5200
      Hello folks, I have a Polaris 500 Scrambler. Not positive I need a new battery.  The folks I got the ride from said they put a new battery on it right before selling it to me. It's been a couple cold months before I tried starting it. After jumping it now, I let it idle plus revved it quite a bit for about 20 minutes. Then I shut it off and tried to restart barely turns over and that's it? Am I not giving it enough charge time maybe need to actually ride it? The battery on it is a Continental CTX9-BX. I lf a new battery is needed would maybe Amazon have a decent one? Thanks!
    • By auditorguy
      My sportsman 800 needs new tires.  Any suggestions for off field and trail riding?  type of tire and or good vendor for them?
    • By Lellwyn Griffin
      Thinking about buy a used 07 Prairie. Any feedback or suggestions on what to look for?
