By hengstserepair
Nuetral: Runs as expected
Lorne
By Rockbottom
By Mister907
By jeffinotown
By en4cer
Problem number 1,
2000 Polaris Xplorer 400. No start, has spark. Has fuel ,found Low Compression less than 60 psi. What to do next?? Going crazy here.
Problem number 2.
1994 polaris Sportsman 400 starter won't engage. Button on left side with light switch seems to be almost stuck in, weak spring behind button?
Any help would be nice.
