I have a 2003 kodiak, 450, that the tail, light is being turned on by front brake control handlebar lever which I dont think should even happen . I have disconnected the brake switch by removing the spring. You can barely touch the lever and the tail light comes on the problem is after parking there is enough contact that the light dont burn but it will run the battery down in a period of 24 hours. Its a good machine with right at 5000 miles and 1500 hours but I am at the end of my rope with it
    • By Fonne
      Hi
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
