Ok i bought a 1996 lt-f4wdx quadrunner and the carburator was not attached? I have a gaurantee that it runs. I know about the throttle and choke but know nothing of where the rest of the hoses fuel drain,vacuum and anything else i forgot about come and or go from or to. the model of carb is a mikuni bst31ss(single carb)! :confused: thanx jim
Pictured are the tubes for your fuel vacuum activators. You might not have the horn in the center depending on your fuel tank valve.
In the back top, two vent hoses that route up underneath the shift lever panel.
Fuel feed goes in lower left near the bowl.
Tim : thanx alot ! i dont understand all the extra hoses? as they go nowhere ? venting maybe? jim
Fuel pump should be on the upper left frame fwd of the handle bars. It is the vacuum that operates the pump.
You might not have the fuel tank valve port on your carb. If your tank valve is the simple on, off, res, type, you don’t need this. If it is the on, pri, res, type, then there is a vacuum port on the back side of it. Vacuum from the carb opens this type valve to allow fuel to flow to the pump.
If you have the simple valve with a carb that has the fuel valve port, plug the carb port. It is not needed.
Do you have a manual for this machine?
Download the OEM service manual for the 1999 KQ model form this forum. It has cable and tube routing diagrams. Much of it will be the same as yours.
Tim: i found the manual ,but i cant down load it for some reason? what am i missing?
Hi tim: i have another issue with the same machine! i cant get a spark,changed the stator,ign coil and the voltage regulator. checked and checked everything twice and still nothing? here is my question, the wires on the stator dont match whats inthe manual? can you tellme where ea wire goes using the colors? and also on the voltage regulator,there are 3 yellow wires,the manual does not say to what wire(color) they go to or does it matter? and does the reverse switch have to be connected for it to start? if so where do they connect to and the colors,please!!!!!!!!!!!! i have checked the cdi and it checks out ok. thanx jim
Says file not found on my BlackBerry. Out riding so not near a computer. Try searching the internet in general for a free download. Or PM Oxidized black.
the stator wire colors are as follows, 3 yellow wires,1 green wire and a black w green stripe wire!
Thanx for ur help,problem solved :-) I need to pick ur brain again if you dont mind? I am workin on another project ( same model,etc) and am having ALOT OF TROUBLE finding a carb for this beast? its supposed to be a mikuni bst31ss 44mil carb and i have searched all over the internet and i cannot even find a used carb to rebuild. so here is 2 questions, can you find a link or someone that may have this scarce animal? If not what would you recomend as an equivillant or replacement to make this animal come alive????????????? thanx again jim :-) here is a pic of the last 1!
    • By Yamahahahaha
    • By GTX-Racer
      I am looking for a PDF version of a manual for a Suzuki Quadrunner 250.  I am not sure of the year, but believe it is a late 1990s model.
    • By USRaider
      Hello all!
    • By Jlars
      Hello, inherited this machine from my father. Runs poorly. Getting fuel in the air box. I’m looking for information on timing  it and bringing her back to life. John
    • By Joeguy
