Any sort of chart created to show which hubs fit upon which axle?
As in hubs from an 07 fit a 87 but the total width increases by 1" per side, etc.
I was hunting down a set of rear hubs to fit on my 1987 YFM350 Moto-4 to get rid of a wobble and read a few pages of search hits here, but other than some comments that many years do fit, I have no real understanding as to what could fit my 1987 or what the effect would be using different hubs.
A chart would help then ordering/buying new rims would be easier when offset changes are known in some chart...
I am shopping for some rears on eBay, some list the year some do not, the 07 Grizzly ones looked like they would fit but increase the width between bolt stud spacing vs the OEM style and thought a chart would help if one were available...
I've interchanged many year Yamaha hubs between models and years. I've never measured any increase in width. The spline size/count works so I use them.
Currently I'm running 4X4 Big bear front hubs on the rear of my wife's 2WD Timberwolf to replace the rear drum brake.
I wouldn't worry about your track width so much as spline fit.
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By tin
    • By nduray3
      Who here hunts with their atv?
    • By bikeoffer107
      List of the NEW and used MODEL OF Motorcycles or Scooters:
      Piaggio,Marietta,Yamaha,Ducati,Supersport,Honda,KTM and More.
      [email protected]
      Call or WhatsApp: + 1-863-300-3370
      New 2025 Kawasaki Z650 ABS -- $4,400usd
      New 2025 Honda CRF300L -- $3,200usd
      Kawasaki Z900
      Kawasaki Ninja 400
      New 2025 Piaggio BV 400 Scooter Motorcycle
      Used 2023 Piaggio Liberty S50 Scooter Motorcycle
      HONDA CB 500 X
      HONDA CRF450R 2022 FULL STREET LEGAL
      Harley Davidson RH975 2024
      HARLEY DAVIDSON ULTRA GLIDE CLASSIC 1640
      Harley-Davidson Street Glide
      SUZUKI GSX600
      Honda vtx 1800
      YAMAHA RAPTOR 700R
      Yamaha YZF-R7
      KTM 1290
      KTM 690 ENDURO R 2020 SUPER
      CAN AM SPYDER 1000
      supersport 950s sportbike motorcycle
      2021 Ducati 950 supersport 950s sportbike motorcycle
      2024 Ducati panigale supersport 950s sportbike motorcycle
      Yamaha Mt 125-MT15-MT03-MT07-MT09 Motorcycle
      Yamaha R1,R15,R9 motorcycle
      If you wish for any model of brand not included above, then send us your enquiry and order quote and we get in touch with you soonest.
      New/Used,Piaggio,Yamaha,Ducati,supersport,sportbike motorcycle ETC
