Kevinjrr
'97 TRX300FW Front Brake Issue
I have completely replaced my front brake shoes, hoses, and master cylinder. I have bled the brakes the best I could. I am still unable to build up much pressure. The wheel cylinders only push out about 1/8" when the handle is squeezed.
What should be the typical travel on the cylinder for the brake shoe to hit the drum?
I've used a brake bleeder, but still can't get all of the air out.
I'm not sure what else to do.
Any thoughts?
Share this post
Link to post
i had to adjust the star wheel so the shoes were almost touching the drum before i got them right. the air is probably out already, but like you said, not enough travel from the wheel cylinders ...
Share this post
Link to post
  • Similar Topics
    • By bren7176
      So honed out the cylinder and got most of it nice nice but left with this .. Might just have to have the things bored out now ..... some before and after..pics.
      1995 Polaris Sportsman 400 4x4
      have to have the things bored out now ..... some before and after..pics..
    • By Gilbey
      Does everyone run the tire pressure as stated on tires or perhaps a couple # below to soften the ride a little?
    • By Randel1
      I am trying to put a 1994 Suzuki 250 quadrunner back into service. I have it up and running like new but need to replace the plastics as they are brittle and crumbling due to age and sun exposure. I would like to purchase new parts either OEM or aftermarket but have had little luck in finding them. I would even consider used or salvaged parts in serviceable condition. Any help in locating these parts would be greatly appreciated. Thanks in advance.
    • By Amazon Ads
      Where do you buy your ATV parts? Did you know that Amazon has ATV parts in stock for immediate delivery? You'll find all the best ATV parts and for great prices! Check out all the ATV parts available with free 2 day shipping now...
    • By William Edwards
      Hello,
      I'm new to the site.  My son and I have decided to bring back our old quad from the dead.  Does anyone know where we can purchase a cylinder kit for it.  I think it's a 1986, but will have to check the VIN to be sure.
      The last time it ran, it was tapping and smoking pretty bad.
      Any help would be appreciated.
      Thanks!
  • Similar Tagged Content
    • By arvellaspoon
      When I push down on the rear brake pedal, it makes the left hand brake very sloppy. Is there a way to adjust that? I have a 2007 Suzuki Vinson
    • By crazynordlander
      Hi All,
      I live in Minnesota and bought a 2016 CFORCE 500 HO. I am in hope to see if there is anyone in the US that is experiencing this sudden drop off in RPM below 4000 RPM. I have uploaded some videos of my issue on YouTube. I will list three of the four I posted. The fourth can be found on my channel but it is a comparison between my Polaris 570 and my CFORCE 500.
      I quit on my first dealer because we just did not mix well together. I brought it to another CFMOTO dealer that just became a CFMOTO dealer in January 2016. They are in a large ranch and agriculture area in a neighboring state that is pretty close to where I live. They have close to every brand available. They are a much larger dealer than the first one I bought the unit from.
      I brought the unit three weeks ago to them and they have worked on it a good solid week and have given up on it. I have read reports from owners in Canada that the dealers there were aware of the issue and have had success in fixing the herky jerky drivability issue.
      I am picking it up tomorrow and bringing it back home. It has been to the trails of the Black Hills this year and was new in late April. 300 miles on it. It has never changed. Very hard to ride on the trails or when I herd livestock.
      Here are the links to my videos.
      I can't accept that this is normal operation. Does anyone from CFMOTO China scan these posts?
      I need help that CFMOTO USA has not provided.
      Kevin
    • By atvfarm
      Ok Im new here. I was given a cougar 250 and i put a new carb on it and it will idle great but anything above low rpms spits and sputters. also is this thing suppose to have a fuel pump or just gravity feed from petcock?
    • By atvfarm
    • By biggreen2010
      ok it will start up an run but quits a lot till it gets warm, but has a bad miss an wont idle, I have a brand new Honda carb on it, good gas flow, new plug, but when I let the throttle go below a quarter, it backfires through carb an tail pipe:confused: so it has never had any electrical work or mechanical work done...it just started all the sudden, I'm think it may have ignition coil breaking down, or cdi box going bad...anyone had this trouble before? let me know what you did to fix it. thanks:skeptic:
