Similar Topics
By Usmc0861
Hey everyone, thank you in advance for any information shared. I have a 99 yamaha beartracker 250 that I am restoring (not to oem specs). I am having trouble finding suspension parts other than ball joints. Does anyone know where i can find shocks/springs for this atv? Are there other yamaha atvs that have interchangeable parts? Or what options might i have. I typically use this quad for hunting, getting around the farm, and trailriding. Thank yall again for any info.
The trailriding includes moderate hill climbs, creek beds, and wet/dry trails
By jeff1
Hey, I’m getting oil coming out of the fill/ dipstick handle when running and I have overfilled crankcase that smells like gas. Would this be a sticking float in the carb?
By Strike37G
Quick question about bolt on valve cover (circled). Is this used for any type adjustment or connected to anything or is it a service vacuum port? Wanting to install a vacuum fuel pump and look like a good spot to connect vacuum. Thanks to all.
By 406offroad
I have a 2014 CForce 500 and the pull start is not cooperating. It seems as if it is not releasing the compression thus allowing me to spin the engine with the pull start. Any ideas?
By PineAppleCawks
Morning all, hope everyone is off to a good start with their day.
about 2 months ago I bought a 95 bayou 300 for a hundred bucks. It was obvious the thing was gonna need some work and I'm up for the challenge. Just looking for some advice on how to get this thing going. The wheeler has an array of problems and I've done a good bit of reading around and learning about the machine lately, but I'm stuck at an impasse and not sure exactly what I need to do to proceed.
So to start with the stuff that was obvious to me; The wheeler has definitely been flipped, the handlebars and steering column are bent, both front and rear racks were bent and have been cut in places to allow the previous owner to bend them back into a rough idea of what they once were. Along with this the little box on the handlebars with the key and lights was completely missing, The ignition wires were hanging out the side and twisted together and the light wires were just freely hanging down below and were also cut, as they have no bullet connectors on them anymore. to deal with the loss of the reverse lockout they strung a cable through a hole in the plastic and attached a random handle to it.
As a preliminary I went ahead and purchased a info box complete with key and reverse lockout and a voltage regulator (as I had read they commonly go bad). I have a small question about the ignition wiring, but I will save this for later as this brings us to the actual problem. No matter how good I do at replacing parts such as this I will never know if any of it has worked because I cant get the transmission to shift at all, but most importantly I cant get it to shift into neutral. I did some research on the problem which consistently lead me to something having to do with the spur gear behind the secondary clutch. I pulled the clutch cover and inspected, Everything was in place with no loose bolts or anything. I went as far as to remove the spur gear and the levers and springs. I could not find any visual degradation that would lead me to believe this part is the issue. With time running thin in the day I went ahead and put everything back in according to the manual. for a brief moment I was very excited to find that the shift lever was actually giving me some sort of tactile feedback and felt as if it was shifting, but this was short lived and it all seemed to jam up and stop doing anything after a few seconds.
When I had the clutch cover off I had my son actuate the shift lever both up and down while I was laying on the ground looking at the spur gear. It seems that every once in a while it was able to grab the spur gear and spin it, but this will ONLY happen if im shifting up. It gets completely jammed trying to go down. Occasionally I can get it to spin partially as I am shifting down, but in those situations it freezes and wont spin any further even if I try to coax it along with a screw driver. What this feels like on the shift lever is there is no feedback. All I feel is the resistance of the spring and then it hits the a spot where it just stops the lever from moving. I get a very distinctive metal on metal "tink" and that's it.
Anyway this is my big hang up at the moment. If I cant get the wheeler in neutral I cant test to see if any of the electronics are working, let alone see if it will turn over for me. As a side note the pull starter is busted, when I pull it I just get the resistance of the spring and it doesn't seem to engage with the motor at all. When the clutch cover was off I grabbed the clutch and spun it clockwise which proved to me that the motor has compression and freely spins.
So that's where I am at now, and I am more or less out of ideas as to what I need to do to either further diagnose the transmission or (fingers crossed) fix it. I figure all the other stuff can wait, as this seems to be the big hinge point on the project at this moment.
I wont be at the farm till later, but when I am I will make a short video of the spur gear so you guys can see first hand what's going on.
I want to thank you guys in advance for any and all advice you may be able to give me. I am glad to have a resource such as this forum and look forward to hearing from you guys!
Similar Tagged Content
- 0 replies
- 1,281 views
- 2 replies
- 1,598 views
- 1 reply
- 3,795 views
- 1 reply
- 2,589 views
- 15 replies
- 3,183 views
Gallery Images
2
5
9By tnfoxracer,
1
3
2By micorps,
0
7
4By tfred13,
0
9By oxidized_black,
2By adammiles,
1
4By globob24,
0
1
1
1
0
0By DJLime,
