By Fonne
Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
By Arizona
Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
too blury and cant tell wire color. Just too small. Thanks Az
By middlebrookgt
Hi All. I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover. It is back together as of last night and cranks up, idles and revs high pretty well. Needs some fine tuning and stop backfiring at stop.
The big issue is it will not go into gear. I reassembled the insides with help from y’all’s posts. The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough. Before I tear it back open, the transfer selector on top does not move as far as the repair manual says. The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
Could this be the problem. I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere. I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc? If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
TIA for any input or feedback!! Pics are from when I first took the generator cover off.
By alexwv1863
I've been working on this 4 wheeler for a buddy of mine. I got it running yesterday and went to ride it around the yard on a test drive. Well, it backed out of the garage fine, but when I went to move forward, it wouldn't move at all. While giving it throttle, the bike would lurch forward as if I had the brake on holding it back. Then it died died on me and wouldn't crank. That sounded like the starter was bound up. It's a new starter that I put on not long ago. It's an aftermarket. Also, when I would rev the engine up trying to get it to move, it sounded like it didn't have much, if any, power. It just wasn't revving right. Anybody have any thoughts as to what could be my problem now? The guy doesn't know what was done to the 4 wheeler by a family member. So anything could be wrong with it. Also, it rolls just fine when I had to push it back in the building. I couldn't hear any clanking or rattling in the rear end.
By alexwv1863
I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
