    • By Fonne
      Hi
    • By Arizona
    • By middlebrookgt
    • By alexwv1863
      I've been working on this 4 wheeler for a buddy of mine. I got it running yesterday and went to ride it around the yard on a test drive. Well, it backed out of the garage fine, but when I went to move forward, it wouldn't move at all. While giving it throttle, the bike would lurch forward as if I had the brake on holding it back. Then it died died on me and wouldn't crank. That sounded like the starter was bound up. It's a new starter that I put on not long ago. It's an aftermarket. Also, when I would rev the engine up trying to get it to move, it sounded like it didn't have much, if any, power. It just wasn't revving right. Anybody have any thoughts as to what could be my problem now? The guy doesn't know what was done to the 4 wheeler by a family member. So anything could be wrong with it. Also, it rolls just fine when I had to push it back in the building. I couldn't hear any clanking or rattling in the rear end.
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
