i have a 2002 honda 400ex, i rebuilt the top end and had issues for weeks not realizing that i had lost the decompression spring and plunger. i finally got new parts and got it back together. it ran great... i took it out for a good solid run rather than just running it in the garage, i made it a good half an hour or so before there was a loud almost knocking noise then it suddenly died, after 15 minutes or so it started right up with no knocking or anything so i thought we would work our way back toward camp, after a few minutes it did the same thing, i might have made it a mile, after it cooled down i got it to start again and then i made it back to the truck... after getting it home i tried starting it and it cranks over and sounds like it wants to start but wont kick over, i re lashed the valves, double checked the timing, checked for fuel and spark... i got it to start once but it just did that same knocking noise while idling and i was afraid to rev it or anything then it died after a minute and i cant get it to start again.
Yeah I replaced the timing chain and tensioner, I double checked them when I tore into it the other day, im pretty certain that the rings were on the right way I double and triple check myself when I'm that deep into a motor.
    • By HHurks
      Thank you!
    • By TomJulio
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By gordonmacritchie
      all fuses are fine
