Hi Guys,
Just wondered if anyone can help, I have just bought a 1990s YFM350 Moto4, and I am struggling to identify the model/ year of the bike. I was told it was a 1997, but would not count on that.
Its a 2WD model with cable operated brakes shoes on the front, cable operated disc at the rear and the choke next to the speedo.
I have been trawling sets of microfiche, but can't seem to find a model with the same brakes as mine.
The only part of the frame number I can make out looks like it starts 2VA.
Thanks in advance, if anyone can help.
Tim
Edited by Davtlc62
you can find the VIN # by the shift lever on the left of the bike ... very hard to see but it is there ,,, flashlight and rag are the best tools and depending on your eyes, a magnifying glass too ... once you have that VIN, you can run it and find out everything you need to know
    • By noticon75
    • By toe420
    • By KIWINZ
      Hello
      My son scored a free Moto4 - late 80s from the looks of it. I don't know anything else about its history as the owner wasn't there when i picked it up. Can't see the VIN number as its a bit rusty.  He cleaned the carb and then with some either it started and still starts first pull.  Its runs really nice - not rattles etc.  Goes forwards well and the brakes work fine so it looks like a keeper, However, we have only managed to get it into reverse once.
      1) it won't shift down into what seems like where first would be - 2nd and upwards only. The changes between gears is fine.  No crunching or missed gears - just no first gear.  2nd gears appears to be as low as it will go
      2) the clutch - when you hold the gear lever up or down works (only the second ATV we have had.  Other is a Quadrunner which doesn't have this feature)
      3) no neutral light - will start when no in neutral - should it do that?
      4) the one time we did get it into reverse the neutral and then the red (reverse) lights worked. Swapped easy between forward and reverse - when it went into second, it didn't return to first or neutral
      5) checked the clutch adjust on the RHS - seemed fine to me.  When i turned the screw back 1/8 it was where it was to start with.  Clutch doesn't slip.  The bike will move forward is all gears.
      Any help would be appreciated
      Andrew
