A Little Wheelie/Reverse Wheelie action.
By Ironworker709
I recently got a great deal on a 2001 Big Bear 400 4x4.it sat in a barn for 2 years while the guy was in college,so it need carb work...got it to use around the property,not racing or anything crazy with it
It runs GREAT and strong..no smoke or funny noises,just seems to have an issue at times ,when you hit the throttle it want's to die ,most of the time it runs strong.
So am debating a rebuild kit or new oem carb...i got to looking around really good yesterday and found this broke off..( the bent tube where the pencil is pointing).... is this a part that comes with a new carb?..if not,,where can i get the part?
I found a diagram online but it does not show the bent tube with a nut on it but says it a "Starter set" in the diagram(Number 21 in the diagram)
I checked the petcock and it is getting plenty of fuel flow..but it has the common drip leak..so i am ordering a new one,..was going to get the seal kit but for the price it is about the same price as a whole new petcock
Just trying to figure out where i can get this part for repair
By Alan Callison
OK ya'll, How do I fix this problem? The plastic part holding the cable in the carb snapped and the spring is slipping out causing a really hi idle speed. I pushed it bacl kin dropping the idle so how can I fix it. I know I can get a kkit but I dont know how to do it. Any help would be appreciated. Thanks.
By Hungus
Hey guys, I know a 2000 Yamaha Big Bear 400 4x4 5 speed single range transmission is model: YFM400FM
But what is the model designation for:
2000 Yamaha Big Bear 400 4x4 "Professional" 5 speed dual range transmission... YFM400F??
VIN decoders don't seem to work for this Yamaha I picked up.
By raymonday1115
Hey I just blew my front shocks on my 2009 can am renegade 800x. Does anyone know of a cheap replacement brand that won't break the bank?
I'm not looking for anything fancy like the original adjustable ones basically just want my tires to quit hiting the fenders so the cheaper the better.
Thanks in advance
Sent from my SM-N986W using Tapatalk
By quadmaniac
View File 2009 Can-Am Renegade 800 Wiring Diagram
Submitter quadmaniac Submitted 05/01/2021 Category Can-Am BRP ATV
