1999 Yamaha Bear Tracker - Leaking Shifter Shaft Seal
vedder37
Title says it all. When I researched part it shows it does not exist anymore, discontinued. What can I do to stop the leak? Is there somewhere else I should be looking for part? The leak is coming from where shifter goes through seal, not around outside of seal between case and seal.
Thanks.
    • By Roofus
      I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
      [removed broken image]
    • By Mhatayas
    • By kiriyaaoi
