My 2005 Kawasaki Prarie 700 will not go over 27mph, seems to have low to no throttle response, dies out whenever you don't keep the throttle up, seems to have no power, and the 4x4/2x4 light keeps flashing back and fourth and also there's a red light on that I'm not sure what it means, any help would be greatly appreciated
Edited by Beckbrenden
  • 3 years later...
  • Ajmboy changed the title to 2005 Kawasaki Prairie 700 No speed
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By marlon smith
      any ideas how to correct
    • By Adamb2025
